problem with idle
Old Jun 19, 2004 | 07:25 PM
ElectricShift's Avatar
Default problem with idle
Hell, if it works, leave it....
Old Jun 19, 2004 | 09:18 PM
Glenlivet's Avatar
There won't be anything wrong with the fuel valve. That doesn't limit the amount of gas available to the carb. In fact there is a fuel pump in the circuit to increase the pressure and supply.
Unless you have a cracked carburater body you are most likely getting flooded because the needle seat is letting too much gas past. That's because it's gunked up, the floats are stuck, or it's worn so that it doesn't seat properly.
Old Jun 20, 2004 | 11:03 AM
4wheelerfred's Avatar
I see. But were is the fuel pump? i cant find it,i looked in the book but it did not say or i am just retardid?
[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jun 20, 2004 | 12:00 PM
Glenlivet's Avatar
It's at the front of the machine. The line from the tank leads to it. But there's nothing wrong with it if you're flooding. <sigh>
Old Jun 20, 2004 | 12:22 PM
  #15
tru. is the thing were you can put it on res/on/pri the fuel velve?
i think it is but i had too ask even thoe it sounds stupid.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jun 20, 2004 | 12:32 PM
  #16
Glenlivet's Avatar
yes. That's the valve. it should be on 'pri' only when you are firing it up after running out of fuel. Use 'on' or 'res' when you need to, from running low on gas. Pri is prime and runs the gas wide open. Use this only when you are starting the bike from running dry. This might be part of your problem if it's on prime.
Old Jun 20, 2004 | 05:01 PM
  #17
ok the idle is now the least of my problems................................[img]i/expressions/face-icon-small-sad.gif[/img].............................
I was driving the quad in too my garage wen i hear this scrshkkksss i stop look @ the left rear axel the U-joint is dead ! ahhhhh now i gotta buy one of those frigin pile of $%^& .
any one know were i can get one cheep i know it is in the range of 300$ but maybe i can get one for less?
[img]i/expressions/face-icon-small-mad.gif[/img] [img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img]
Old Jun 20, 2004 | 05:35 PM
  #18
jsyi's Avatar
I think you should trade your quad in for a tricycle....less problems.
Old Jun 20, 2004 | 05:42 PM
  #19
Glenlivet's Avatar
Look on eBay using 'suzuki king' as a search, there are a couple of guys with a hoard of parted out kings or use your favorite search engine and use 'ATV salvage' for search words. You're bound to find a place near you.
Old Jun 20, 2004 | 05:50 PM
  #20
thanks!
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 12, 2015 06:34 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
MNatv89
Jul 7, 2015 11:36 AM
