need rejetting help
Old Jul 22, 2004 | 12:28 AM
MBrooks420's Avatar
Default need rejetting help
You need to ride the bike for at least a half hour to get a reading on the plug. The electrode should be a nice tan. Black or dark brown is a little rich, white is lean. Since it is heating u[p abnormally I'd try the plug once after 15 minutes. I'd also not take the plug out/ put it in when it is hot, as it can damage the threads.
Old Jul 22, 2004 | 12:59 AM
WHYNOT's Avatar
thanks alot for all the help MBrooks420
I think I'll go ahead and put a 155 jet in it while I have the plastic off and see how it looks then after riding it.If that doesn't do it I've got a 157.5 & 160 I can try
Old Jul 22, 2004 | 10:19 PM
craZ400's Avatar
Did you do anything to adjust the needle yet? Not really anything to do with the heat prob, I was just wondering. On the heat issue, Mine was the same way, I just contributed it to the fact that the engine is sucking more gas/air thus creating more heat much faster. If your fan isn't kicking in, and there's not a prob with the thermostat, then I wouldn't worry to much about it heating up fast, as long as the temp levels out. JMO
Old Jul 24, 2004 | 06:24 PM
WHYNOT's Avatar
This thing is giving me a hard time. With a 157.5 main, air lid off it runs good on the top end(plug chop was good). It ran like crap 0 to 1/4 throttle so I put in a 25 pilot jet and adjusted air/fuel screw and got 0 to 1/4 going good but I can't get the mid throttle to respond like it should. I shimed the needle up not much changed shimed it down not much changed. It idles great and cruises at any speed fine, you can roll the throttle in & out normal and it picks up/ drops off like it should, but if you gun it in 1st or 2nd gear it bogs for a second then picks up and hauls a$$. I don't know what else to do. Anybody have an ideal of what circut to adjust??
Old Jul 24, 2004 | 08:17 PM
  #15
hondabuster's Avatar
Make sure there isnt a vacumn leak in the diaphram. Make sure the top is sealing good and doesnt leak.
Im assuming, youre experiencing bog from throttle off, to open? If so, then the idle cicuit is still too lean. Either go more rich with the mixture screw, or if its more than 3 or 4 turns from seated now...then you need a bigger pilot jet.
Old Jul 24, 2004 | 11:54 PM
  #16
WHYNOT's Avatar
Well I final got it tuned right. I put in a 27.5 pilot, turned a/f screw out 1 1/2, shimed needle, and put in a 160 main jet, and running a step cooler plug. It has very , very good throttle response at all positions and is strong out of tha hole.(just what I wanted). I would also like to think everyone that helped me out, the advice was very apprecated and helpfull.
Old Jul 25, 2004 | 09:31 AM
  #17
ZukZilla550's Avatar
Hey WHYNOT anytime,this forum rock's when you need help.
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
cSchwartz
Jul 9, 2015 02:43 PM
Bm400ex
Jun 22, 2015 09:16 AM
quad_300ex
Jan 23, 2000 10:17 PM
