zilla tranny problems
Old Sep 19, 2004 | 09:29 AM
dirtdawg's Avatar
Default zilla tranny problems
My 89 zilla is starting to not shift into 2nd gear under hard acceleration when speed shifting it seems like it will not go into 2nd or hits neutral and a couple times it goes right into 3rd from 1st .It seems fine under normal riding but when drag racing is when the problem occurs.What should i expect to have it fixed and who would you suggest doing it?Thanks Jason
Old Sep 19, 2004 | 11:49 AM
ZillaRider02's Avatar
When I had tranny problems (popping out of gear, hard to shift) I took mine to a local shop that only does ATV work. I pulled the engine from the frame, then took the cylinder off and took him the bottom end. Labor to split the cases was only $100. He replaced all the shift forks and some various small pieces. No problems since. You could send it to a bigger shop (Trinity, LRD, Etc) but be prepared to pay!
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
hondarider1234
Jul 21, 2015 11:53 PM
coolguy420
Jul 10, 2015 01:17 AM
