lt250r won't start>?
Old Jan 25, 2005 | 12:00 AM
  #21
NichelsonRacing87's Avatar
Default lt250r won't start>?
Originally posted by: revhardlt250r
anyway it was runnnning fine and then it jus bogged out! all i did was put a 190 main jet in and mix my gas 32:1..can't figure it out!!!????
i mix my gas for the LT at 20:1, but that most likely is not your problem, i got my fuel mixture ratio out of the Clymer's manual for the LT
Old Jan 25, 2005 | 12:04 AM
  #22
pendejo's Avatar
I don't know what oil you're using, but I would read the back of the bottle and go by the oil manufacturer's recommended ratio.
Old Jan 25, 2005 | 01:08 AM
  #23
Semms40oz's Avatar
ok i got some specs from the manual/clymers.... main jet stock on a mikuni carb is a 240 stock (87+)... needle in the 3rd clip position... this is for your altitude in general. unless your running a kihein carb you are very lean... still looking for compresion specs. its not obvious in the TOC and i just don't have the time to read through the chapters right now... i will post it as soon as i find it.
Old Jan 25, 2005 | 01:54 AM
  #24
pendejo's Avatar
According to another thread, about 120 lbs for compression.
Old Jan 25, 2005 | 07:05 AM
  #25
1987LT250's Avatar
i have 160 lbs compression but thats with 2 tanks gas through total rebuild. if it bwas me i would put shot gas in plug hole try to start if no luck i would definately pull the left side case cover over mag and pull the mag wheel off and look at that woodruff key on crank that holds flywheel in place. sometimes it doesnt sheer the key all way just tweeks it and that little bit will make it slightly retarded and it will backfire/kick back at ya when kicking and wont start.
Old Jan 25, 2005 | 10:51 AM
  #26
trickeytech's Avatar
the woodruff key was a problem i had with my last Lt, it to had the same symptoms
Old Jan 26, 2005 | 04:13 PM
  #27
revhardlt250r's Avatar
na..[img]i/expressions/face-icon-small-sad.gif[/img] i lost compression!!! i think i might have a broken ring..i don't understand it i just rebuilt it over the summer2..well guess i gotta do it again...any 1 know what size jet's i should use and air srew>? and should i take my air box off..? should i get g-force reeds>?
Levi Enstad
Sep 26, 2015 08:00 AM
Halffast17
Sep 11, 2015 02:30 PM
LTqracer
Sport Quads
19
Jun 2, 2004 07:20 PM
donpeter
Apr 4, 2001 12:31 AM
Steve10
Aug 2, 2000 03:32 PM
