need wiring diagram lt250r
Old Nov 9, 2022 | 09:33 PM
  #21
Junbug69's Avatar
Originally Posted by 1987LT250
there is no wire that goes from the mag to the coil my scanners un hooked or i could scan ya the diagram. 3 of the four wires from mag goto cdi and come out of cdi . im not sure what your question is but the black out of cdi goes to coil if thats your question and black and white from the ground goes to other side of coil. if you can rephrase your question ill help ya in any way.good luck
There is no sold black wire from the cdi
Old Nov 10, 2022 | 01:43 AM
  #22
Junbug69's Avatar
Do u have to have the black and yellow from the cdi hooked up
Old Nov 10, 2022 | 03:12 AM
  #23
Wiring diagram shows plain black from CDI to ignition coil. Check what colour wires go to that coil. Wiring diagram also shows yellow/black wire to be kill wire but doesn't indicate if it is earth to kill or earth to run. If it won't spark with the yellow/black disconnected, try earthing it and see if you then get a spark. The diagram is for 87 models though, other years may be totally different.
tombrown14
Aug 26, 2015 07:30 AM
Atvnewb88
Aug 19, 2015 02:22 AM
Atvnewb88
Aug 13, 2015 06:48 AM
Tadej Dylan Vuzem
Jul 27, 2015 07:26 AM
tweeder
Jul 5, 2015 01:57 PM
