LTZ400 Misfiring
Hi I am new to the forum and I have a problem with my 03' Z400. When it strats it fires up no problem with the choke on. Once you start to take the choke off as it starts to warm up it wants to turn off and starts to run rough. If I rev it up and let the throttle off it sounds like its backfiring city. I checked the petchock valve to make sure gas was flowing seems to be fine. It seems like its the carb but I don't know. Can somebody help?
Sounds daft but is there enough fuel in the tank?
Had the same problem with the Z250 which would run Ok on prime but backfire otherwise...........the tank was low on fuel and the lower of the two pipes on the petcock was still dragging fuel but the upper one wasn't!!!!!!!!!!!!
No comments lads!!
No comments lads!!
pull of the floatbowl and clean the cab real good. Also, may want to clean your air-filter why'll your at it.
yea i just had that problem with mine it would fire up nicley and idle but when i went to give it gas it shut off then i was checking around on it and i drained my gas tank and there was some little pieces of mud in there that was blocking it from flowing
Yah. I took the petchock of and found some little pieces of dirt or crud and cleaned it out pretty good. It seems to be working ok now thanks to everybody's suggestions. [img]i/expressions/face-icon-small-smile.gif[/img]
Lou Domenech
Sep 11, 2015 06:35 PM
Jun 3, 2015 01:40 PM
