2003 Vinson Front Shaft removal
Old Apr 17, 2005 | 11:20 PM
Joks's Avatar
Default 2003 Vinson Front Shaft removal
Are any special tools needed to remove the front axle? Snapped the outer CV joint this weekend. Thanks
Old Apr 18, 2005 | 11:52 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
Remove the nut on the end of the axle, the upper and lower ball-joint nut and bolts, then the axle will pop out with a good jerk or pry it out.
Old Apr 18, 2005 | 12:16 PM
Vinson581's Avatar
best thing to do is to get yourself right infrount of it, and just give it 1 or 2 good yanks and it will pull right out. while the axle is out stuff you towels in the hole so the frount diff fluid doesnt run out....and if you havent changed it now is a good time.
v581
Jmuddin284
Jan 19, 2026 07:16 AM
jettman
Jul 6, 2015 12:16 PM
Jkfx400P
Jul 6, 2015 10:04 AM
Shifts
Jul 3, 2015 07:59 AM
Mphillips
Jul 2, 2015 07:20 PM
