Eiger oil and fluid
Old Oct 13, 2005 | 10:46 AM
ekyle's Avatar
Default Eiger oil and fluid
I have an 02 Eiger 400, 4wd, Auto. Bought it used.
The manual is on the way, but not here yet.
My question is?
I found the oil dipstick and the brake fluid is easy enough to check.
What other fluids to I need to check and where are they located?
Thanks.
Old Oct 13, 2005 | 12:52 PM
alleycat's Avatar
differential fluid should be checked every 1200 miles and replaced every 2 yrs. as per 2004 eiger manual. should be the same for the 02.
Old Oct 13, 2005 | 01:54 PM
ekyle's Avatar
Where's the check plug and what do they recommend putting in it?
thanks
Old Oct 13, 2005 | 09:35 PM
alleycat's Avatar
The plugs are on the side of the differentials. It is a metal plug that is removed with a hex key of some sort. You will notice the plug when you look at the unit. They recommend SAE90 hyploid gear oil with a GL-5 rating.
MaasaiMomma
Mar 25, 2021 11:24 AM
hueby
Nov 6, 2015 11:34 AM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
Technical and How-To Articles
Aug 21, 2015 09:31 AM
baysport
Jul 23, 2015 11:37 AM
