z250s
Old Feb 17, 2006 | 07:55 AM
  #481
133's Avatar
133
Default z250s
Im buying brand new 06
Old Feb 17, 2006 | 01:56 PM
  #482
91CavGT's Avatar
Default z250s
Originally posted by: LTZGUY
The head was very easy to port. I used a snap on long reach air grinder, a couple different sized ball bits, a pointed bit, and a few cartridge rolls. Keep in mind you cant just go grinding on a head without knowing what you are doing. I have ported many heads as i have access to a flow bench so i have done a little testing and research. I have done many automobile heads, a few briggs 5hp heads and I have a little practice on my friends klx110 pit bike before i did my z250 head. This atv is probably one of the easiest to work on which is how i pulled the head off, ported it, and put it back on and was riding in less than 4 hours. The only thing I can tell you is if you can't port it yourself or know someone who can, you can send it to me and i'll do it for $100. you'll need to send your head pipe to because it has weld protruding into the pipe.
I might take you up on that offer and send you my head to get ported with a new cam after I get back from Mud Nationals. If that is, if I don't blow the motor out there!!
Old Feb 17, 2006 | 05:23 PM
  #483
133's Avatar
133
Default z250s
Might just get some diff rims and run 24's for the deep stuff, im gonna mud with a z250!!
Old Feb 17, 2006 | 05:37 PM
  #484
dunbarr's Avatar
Default z250s
Same here, it might be a few weeks for me
Old Feb 17, 2006 | 06:26 PM
  #485
91CavGT's Avatar
Default z250s
I just won an auction for a small IHI RHB5 turbo. I am currently looking at what all it would take to install it on my Ozark.
Yes, it is a bit too big for this motor
Yes, it will have lots of lag
Yes, it will be a PITA to tune
Yes, it will slow the quad down when not in boost
But, it will be sweet when/if I get it on there and running!! There aren't very many turbo quads out there, and out of all the ones you will find, you won't find any 250 cc turbo quads.
btw, I am not new to turbocharging and I have a few tricks up my sleeve to get it to spool quicker.
Old Feb 17, 2006 | 10:20 PM
  #486
133's Avatar
133
Default z250s
If you can get the man. clutch itll help you spool it up before you hit the pit.
Old Feb 18, 2006 | 12:27 AM
  #487
suzukirider55832's Avatar
Default z250s
sorry i haven't been on in a while...i was at my friends...but i'm back now...the clutch will help you out a lot...whoever wants the new z250 go for it and i've seen a z250 w/mudlites and they perform very well...as for the regulator, i would say never bvuy anything from procom i ordered a procom product and it fu(ked up my battery...
Old Feb 18, 2006 | 01:03 AM
  #488
LTZGUY's Avatar
Default z250s
A turbo would be cool if you could get it to work. the things you'll run into (literally) is that damn rev limiter, and from what i hear turbos don't work too well with a single cylinder engine. They need multiple exhaust pulses. You could use a chamber in the exhaust before the turbo and that would smooth out the pulses enough to make it work. If you could do anything to make the turbo rotate easier and make the rotating parts lighter that would help too. I have actually considered putting a turbo on mine but i don't feel like getting a headache. By the way, anyone wanna buy a Yoshimura Slip on for their z250? I'll let it go for about a hundred bucks with shipping.
Old Feb 18, 2006 | 01:41 AM
  #489
dunbarr's Avatar
Default z250s
Darn you should have said that a few hours earlier, just gave some money towards my bike[img]i/expressions/face-icon-small-sad.gif[/img]
Old Feb 18, 2006 | 10:12 AM
  #490
Default z250s
LTZGUY i would buy your yosh but i already picked my pipe out...we have attracted so many people into this post it's not even funny..
