problem with 06 eiger
Old Dec 31, 2005 | 12:42 AM
taesman's Avatar
Default problem with 06 eiger
went riding on my 06 eiger the other day. stopped and shut it off but when i returned to start it i put it in neutral and the neutral light would not come on and it would not start. i had to put my right hand brake on to start it. (the reverse light also will not come on). i took it back to my dealer the other day and when i got there everything worked like it should. i brought it back home and rode it and the exact same thing happened again. i parked the bike until the next day and when i went to ride it again everything worked. when i shut it off and tried to strart it again no neutral light, no reverse light ,engage brake to start. has anyone had this problem or can tell me what it might be.
Old Dec 31, 2005 | 01:19 AM
IdahoVinnie's Avatar
Is it an automatic? If it is similar to my Vinson, there is a 6 pin connecter that is on the left side (as sitting on it), near the upper right corner of the large opening of the plastic (the opening that allows you to see the rear of the engine and carb). This harness disappears into the right side of the case, in line with the shift shaft (drops into case on the right side, inside of the belt and clutches). Inside of the tranny is the gear selecter sensor. Check this connecter to see if it is fully connected together.
Old Dec 31, 2005 | 02:12 AM
taesman's Avatar
my bike if 5 speed
Old Dec 31, 2005 | 02:38 AM
aksafari's Avatar
Go outside and try using the kill switch on the left handlebar to duplicate your problem.
Old Dec 31, 2005 | 04:42 PM
taesman's Avatar
my bad! it was my left hand brake.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
baysport
Jul 23, 2015 11:37 AM
hondarider1234
Jul 21, 2015 11:53 PM
