Z400 remote oil tank, overfull
Old Feb 17, 2006 | 01:27 PM
MR2xxx's Avatar
Default Z400 remote oil tank, overfull
This is my first bike with a remote oil tank and when I went to check the oil, it flowed out of the tank as soon as I opened it. I thought it might have been because the engine was just running a few minutes ago, but I checked it again after the bike sat overnight and the same thing happened. I take it this means the tank was overfilled?
When the bike has been sitting(cold engine), there should be no oil flowing out of the oil tank when I unscrew the cap right?
I assume the previous owner overfilled it, but how could he have overfilled it that much?
Old Feb 17, 2006 | 06:04 PM
MURDR's Avatar
Yeah, its over filled. Just go some where nobody is a round and just tilt your bike a little bit with the oil dipstick removed.
Old Feb 19, 2006 | 10:31 AM
madmad's Avatar
Yes, its over filled, two options, one, change the oil and filte,r or two, remove the drain plug and drain some out.
Old Feb 19, 2006 | 09:37 PM
KyJoe340's Avatar
What year is your Z? If it's an '05 or '06 this might be signs of a bigger problem. The magnesium covers are causing a corrosive problem with the coolant (I'm sure everyone is aware of this now) and after time coolant can get in your oil and cause the over filled situation you described. If you just bought the bike I would change the oil anyway, I bought a used Z and the previous owner had the oil filter in without the O-ring seal.
Old Feb 19, 2006 | 10:31 PM
MR2xxx's Avatar
Thanks, looks like I'll have to drain some of the oil out.
Old Feb 20, 2006 | 04:52 AM
MIDDLEAGEDCRAZY's Avatar
Your right. But if the coolent was getting into the oil, It would cause A milky color. If that is not happening then I would figgure it was overfilled. If I had just bought the bike The first thing I would do is change all the fluid's. As well as grease everything. You never know how how often someone elese doe's these thing's. I was talking to A guy awile back that had his bike for two year's and said he never had the breakin oil changed, Just add's more oil as needed. [img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-shocked.gif[/img] Some people just don't care or have A clue.
Old Feb 20, 2006 | 09:04 AM
z838mx's Avatar
The best way to make sure you dont over fill the oil is when you change your oil there is a sticker on the side of the oil tank it says 2000ml put in 2000ml and then run the bike to operating temp turn it off and let it sit for a minute then check your oil I have noticed when I change mine even when putting the correct ammount in you might still need to add a splash. I used to over fill mine because I dident let the oil run through the system correctly and I would just check it without running it you cant do that you have to let the oil circulate through the system. Hope this might help. And I woulden do what murder said by going somewhere nobody is looking and dump it out that would be irresponsible. Not to flame you murderer.
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
toonces
Sep 5, 2015 01:14 PM
