My new Eiger is having issues. Need suggestions
Old Jun 3, 2006 | 10:55 PM
trentmh's Avatar
Default My new Eiger is having issues. Need suggestions
This week I purchased a manual Eiger from an individual and it only had six miles on it so it was basically new (he won it in an auction, but already had a Honda that he preferred). I've driven it around the yard a few times and it has always cranked within a couple of seconds and idled fine. Today I had the opportunity to take it out and really ride it in an effort to get a good start on completing the break-in procedure as dictated by the manual. After about 8 miles of riding today, it kept wanted to die and the throttle was very sluggish at first. I had to keep my thumb on the throttle or else it would die. On the 3 occasions it actually did die, it was very, very hard to start. The last time it died I thought I was going to have to walk back to my truck. I sat there trying to get it cranked for about 5 minutes. In order for it to crank I had to give it what seemed to be an enormous amount of throttle. Once it finally cranked, it was missing bad up to about 1/4 throttle, but seemed better above that. After sitting for about 4 hours, I went back out tonight and it fired right up, idled fine, and ran like a champ.
I would hardly ever be mistaken for a mechanic and I plan on taking this to either to my local Suzuki dealer or an independent shop. I have two questions really: 1) Is this type of failure something that is generally covered by the factory warranty? 2) Any ideas as to what this failure may be? Any help would be appreciated.
Old Jun 3, 2006 | 11:19 PM
LimpingLizard's Avatar
Try cleaning the carb. Our Eiger's seem to be notorious for crap getting in there. Definitely add an inline fuel filter. I haven't had an issue since adding mine.
Old Jun 3, 2006 | 11:42 PM
rolsmojave3's Avatar
yes, clean the carb really good...also...if it happens again, use your choke that'll help you get back to the truck. Good luck on the new bike...great machines
Old Jun 4, 2006 | 01:59 AM
trentmh's Avatar
Thank you for the suggestions. I'll get a service manual on order and once I have a good understanding of what I need to do, I'll get after it!
Old Jun 4, 2006 | 02:00 AM
DDDonkey's Avatar
I had the same problem when I got mine back from the shop after they adjusted the valves. I had the clean the carb like everyone esle said, put a $2 inline fuel filter and found the vent hose for the carb was pinched, the one that goes up but the intake. Fixed my problems.
Old Jun 4, 2006 | 03:10 PM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
Also check the fuel cap vent hose and make sure it isn't pluged.If it runs better with the choke on it is a lack of fuel problem. Pull the fuel line off of the carb and see if fuel flows good with the petcock on prime. Cut the line and install a fuel filter. Where the line hooks to the carb there is a small screen in the tube. Use a soft wire to clean it out. Crank the engine with the line unhooked and the petcock on run and see if fuel flows good. If you have good flow, hook the line back to the carb. On the bottom of the carb there is a screw to drain the float bowl. loosen that screw and see if fuel flows good from there. If not the carb needs to be cleaned.
Old Jun 5, 2006 | 12:59 AM
Hemi4u2nv's Avatar
Is the choke on? I made that mistake right after I got mine. Wife's started running more poorly the more we rode and started dying when we'd stop. Choke was on about 1/4.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
CosmoM
Sep 21, 2015 04:57 PM
alzgarvin
Sep 11, 2015 08:53 AM
Steeldon
Sep 9, 2015 09:38 AM
toonces
Sep 5, 2015 01:14 PM
