Eiger not shifting back into 2WD!!
My '02 Eiger Manual does not shift back into 2WD very well. It will shift fine into 4WD (from neutral) but when I stop to shift back to 2WD (in neutral) it stays in 4WD. Any suggestions?
You could also check inside the 2wd/4wd lever on the bars. There is a small, white plastic cam on the end of the cable - if it breaks it will default to 4wd.
Jaybee
Jaybee
Thank you guys! I will check each item you mentioned. I feel like it just needs adjusting (somewhere) because of how well it goes into 4WD.
I had posted earlier about my Eiger "bogging down" at high speed and have come to the conclusion that it was because my 2WD was not fully engaged and it was slipping in and out of 4WD making the front end go down...causing me to think something was wrong with the engine.
Thanks Again!
Thanks Again!
bzdok1234
30
Feb 23, 2016 01:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
