braking issues
Old Aug 4, 2006 | 06:50 PM
cataway's Avatar
Default braking issues
i called a Suzuki shop and told them whats going on .when i said that the handle comes against the grip ,than thats its most likely the master cylinder . he said that there is 2 small holes and that most likely the small hole is blocked .and that i should use carb cleaner and back blow it with high pressure air. so I'll let ya know what happens.
Old Aug 4, 2006 | 11:47 PM
jray3369's Avatar
I was having the same problem, I went out and did what the dealer told you to do and it fixed my lt250r. I bleed the lines and went over the pads and looked at everything but grime in the reservoir was it.
Jordan
Old Aug 5, 2006 | 06:00 PM
cataway's Avatar
not much better saliva
Old Aug 5, 2006 | 07:13 PM
hondabuster's Avatar
When you bleed...does air come out? Or is it just fluid?
If you jack up the front end...and spin the front tires by hand...is there drag, or does it spin freely?
I still think its stuck slider pins...its very common for them to sieze up. And when that happens...the brakes kind of work, wont lock up, and the handle nevers gets firm until it hits the handlebar.
COFatboy
May 2, 2020 12:06 AM
greg74
Sep 10, 2019 03:03 PM
DeFox500
Jul 26, 2015 06:32 PM
Unzzy66
Jul 11, 2015 10:01 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
