Dies when I give it gas ???
Old Dec 10, 2006 | 12:40 PM
Glenlivet's Avatar
Default Dies when I give it gas ???
Putting magic gunk in the tank won't do it. You need to clean that carb.
Old Dec 10, 2006 | 07:33 PM
ds650forlifeson's Avatar
replace the spark plug it will idle just fine but till you give it gas its not making enouph spark for it to gain rpm change it then write me back
Old Jul 4, 2020 | 11:19 AM
Caden Justinger's Avatar
Default choke stuck closed
Originally Posted by GJRonK
My guess would be restricted air flow--either dirty air filter, choke stuck closed, or something blocking the air intake tube. After a couple of minutes of idling, you shouldn't need the choke on.
GJRonK
how do you fix the choke stuck closed
Old Jul 5, 2020 | 04:38 AM
That quote is a load of old toot. The OP's engine was running weak, if the choke was the problem it would be running rich and get worse as the engine warmed, same for dirty air filter.
It depends on what model you have, as to how to fix a stuck on choke.
fordfaithful21
Dec 7, 2015 05:52 PM
scram5050
Aug 19, 2015 02:19 AM
cdoren
Aug 16, 2015 11:22 PM
house1
Aug 9, 2015 10:49 PM
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
