BIG PROBLEM!!!!!!
Old Oct 28, 2006 | 11:34 PM
suzukirider6490's Avatar
Default BIG PROBLEM!!!!!!
I have an 87 Lt250r. Me and a couple of friends were rippin around all day today, and then it started to bog out on me. i stopped and it started to smoke cause there was an antifreeze leak somewhere. well anyways we eventually pull started it cause it wouldnt kick over. it was runnin ok and then it just sort of shut of then when i went to kick it, i couldnt cause it was locked up. What do u think the problem is and how much approximately will it be to fix. i think the pistons are seized or somethin but i dont know a whole lot about motors. any help would be appreciated
Old Oct 28, 2006 | 11:47 PM
lt250rh's Avatar
you either seized it or the head gasket is leaking coolent into the cylinder
Old Oct 29, 2006 | 12:19 AM
how much would that cost me though?
Old Oct 29, 2006 | 12:43 AM
lt250rh's Avatar
it is about $7.00 to $10.00 for a head gasket. if you seize the engine it would be about $150.00 to $200.00 but you need to pull the plug and see what it looks like first.
Old Oct 29, 2006 | 02:42 PM
what do u mean pull the plug and see wut it looks like? wut am i lookin for? and would coolant leakin into the cylinder actually cause the kick starter not to move?
Old Oct 29, 2006 | 11:02 PM
lt250rh's Avatar
pull out the spark plug and if it's running good it should be light brown to tan if enough coolent got into the cylinder it would be locked up tight at the kick starter
Old Oct 4, 2008 | 07:17 PM
Freddyfireball's Avatar
If i were you i would pull the drain plug at the bottom of the motor, if you see antifreeze in the oil then thats your problem
Old Oct 4, 2008 | 08:58 PM
mucky's Avatar
Default BIG PROBLEM!!!!!!"></title><script src=
<div class="FTQUOTE"><begin quote>Originally posted by: suzukirider6490
would coolant leakin into the cylinder actually cause the kick starter not to move?</end quote></div>
yes. its called hydrolock, if its on top of the piston water and coolant wont compress and it locks the piston. remove the spark plug and see if it turns over. if it doesnt then its a new top end. piston and cylinder and maybe a head
Old Oct 5, 2008 | 12:15 PM
QWODER's Avatar
you shouldnt run it with antifreeze leaking.It probably got hot and locked up.I guess you meant the antifreeze was leaking on the outside of the motor and not into the engine cylider.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
