96' lt80 gas leak
Old Nov 30, 2006 | 07:59 AM
MadCalf's Avatar
Default 96' lt80
Gas leaking from unknown location.
Having trouble starting and after trying to start it just about all of the gas leaks out from unknown location.
Doesn't start leaking right away that I know of maybe in about 5 to 10 minutes.
Anyone have any suggestions.
Thks
Old Nov 30, 2006 | 10:14 AM
LT80's Avatar
LT80 Expert
Default 96' lt80 gas leak
Clean the carb.make sure you remove the needle seat and clean well.
Also blow back thru the fuel supply hose to give the petcock a lil cleaning. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 30, 2006 | 10:22 AM
MadCalf's Avatar
I have cleaned the carb and corresponding components. I even swallowed the petcock LOL
Old Dec 1, 2006 | 11:48 AM
LT80's Avatar
LT80 Expert
You loose the O-ring that seals the carb to the reed cage?
Not starting tells me:: too much fuel or an air leak.
You running the petcock on prime or run position?
Old Dec 7, 2006 | 09:33 PM
QWODER's Avatar
flaot could be hanging up.does the carb have a line off the bottom of it.if the fuel is coming out of that line then your float is probably hanging.if fuel is coming out of that line,tap on bottom of carb and see if this stops it.
Old Dec 7, 2006 | 11:54 PM
LT80's Avatar
LT80 Expert
Not on this carb qwoder. [img]i/expressions/face-icon-small-sad.gif[/img]
exmotocrosser
Sep 13, 2019 06:12 AM
QuadRiders
Oct 22, 2015 04:13 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
merryman
Sep 19, 2015 03:15 AM
