r450 cherry bomb gone wrong
Old Jan 25, 2007 | 11:25 AM
IL0VELAMP's Avatar
Default r450 cherry bomb gone wrong
i installed an 06 cherry bomb for an 06 r450 on my 06 r450 yesterday and the intructions said to remove the rubber boot on one of the connections up front and plug in there. On the quad the only connection with a black rubber boot has a different connection. There is a connection with a white end cap that fits it though. Anyone else have this issue? is there anyway to tell if its working? should i be able to hear a difference?
Old Jan 25, 2007 | 06:31 PM
z250freak's Avatar
I dont know what plug you are talking about but there is one right above the right front shock. It has a black rubber cap on it that you need to take off and there will be a while plug underneath that, that is what you plug it into, then ziptie it to the frame. Did you take the baffle out of the exhaust and take the airbox lid off too? If you did, you will notice that it will be much louder and will have a lot more snap. If not, do it now.
Old Jan 26, 2007 | 12:10 AM
IL0VELAMP's Avatar
well i checked again but its the same, the only connection with a black rubber boot has 4 connectors inside it, the cherry bomb requires six and i found another connection with a white end cap with 6 fits perfectly but how do i know?
Old Jan 26, 2007 | 12:14 AM
4wheelerfred's Avatar
plug it in and see if it works
Old Jan 26, 2007 | 12:27 AM
IL0VELAMP's Avatar
How do i know if it works? will i be able to feel/hear the difference?
Old Jan 26, 2007 | 01:18 AM
IL0VELAMP's Avatar
Lets look at it differently, how many connections in the front will fit the cherry bomb? just one right? how many connections are there total? i'm guessing that something got messed up when the dealer put it together, but i hope im connected in the right spot. On mine there are two connectors on with a black boot one with a white one the black boot one wont fit, its a different style, the white one fits perfect. can i get someone to check their machine and see how many connectors there are?
Old Jan 26, 2007 | 01:24 AM
IL0VELAMP's Avatar
does anyone know if its true, that you have to disconnect the battery to reset the efi through the cb?
Old Jan 27, 2007 | 08:58 PM
LTZGUY's Avatar
Lets make this simple. It will only plug into the plug its supposed to fit. simple. if it plugs in, thats the right plug. you will not hear a difference by simply plugging in. you will feel a difference if you take out the baffle and remove the airbox lid. If you do not remove those two items, your bike will be slower jus plugging in the c.b. also, get you a k&n extreem air lid or an outerwears velcro on lid.....jus a lil extra insurance. The outerwears won't let water in, but will let in all the air you need. Have fun
Old Jan 29, 2007 | 12:34 PM
RaptorOwner's Avatar
Yep this is all true!! I got the velcro setup by outerwears and its awesome!!!
bmxatv10
Oct 14, 2022 06:23 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Clint Russell
Sep 25, 2015 03:20 PM
cboler9
Sep 24, 2015 08:35 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
