ltz50 quad no power
Old Nov 20, 2007 | 04:34 PM
  #271
EdKatt's Avatar
Default ltz50 quad no power
What about drilling the rollers evenly?
Old Nov 20, 2007 | 04:52 PM
  #272
tbirdsc50's Avatar
well i removed 3 roller big change, , if you drill, you will need ascale that weigh in grams ,i think thats a big risk if you dont drill each right ,
my problem is cant find a air filter ,
Old Nov 20, 2007 | 04:58 PM
  #273
EdKatt's Avatar
Yeah the drilling is too risky! Removing the rollers gave you more bottom end and less top speed?
Old Nov 20, 2007 | 05:15 PM
  #274
tbirdsc50's Avatar
welli have not gotten the cdi box yet , getting from e-bay, i do think we gained some top end , lot oh bottem end , ED what air filter did you use and were did you get it
Old Nov 20, 2007 | 05:30 PM
  #275
EdKatt's Avatar
I haven't got one yet bud! CTRacing.com has a k&n with the outerwear for about $50 bucks. Check it out. I have a friend who can get k&n for cheap so Im probably just going to take off the stock and measure the carb inlet. After you have that you can go on k&n's website and choose from their universal filters. Im sure thats what CT did. Its a simple little filter. Or maybe Ill just pay the 50 bucks!!
Old Nov 20, 2007 | 05:36 PM
  #276
EdKatt's Avatar
I ordered a fmf pipe from Dennis Kirk for a Christmas present. It looks good and is way cheaper than CT's pipe. Im going to put that pipe on it, get the k&n filter and then change the sprocket. After that Ill probably have to get the cdi. I guess I better try removing those rollers also!
Old Nov 20, 2007 | 05:45 PM
  #277
tbirdsc50's Avatar
for now i just drilled the exhaust , i went to k&n ,they had a stop to put you size needed ,it came up with no match, i might try callin after the weekend , if i find out they thing i will put on soon as i can ,
Old Nov 20, 2007 | 05:49 PM
  #278
EdKatt's Avatar
Yeah my exhaust is drilled already. Ill call k&n soon and post what I find out.
Old Nov 20, 2007 | 06:36 PM
  #279
burtcampbell's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: EdKatt
I didn't have to change the jets when I drilled out my exhaust, just had to adjust the air/fuel mixture.</end quote></div>
EdKatt,
Can you tell me what you did to change the mixture. I know there are 2 adjustment screws. The one in the center of the carb is idle and all it does it raise the needle just like giving more throttle. Then there is a screw to the right of that closer to the air cleaner and I think that is to adjust the air somehow, but I dont fully understand it. Can you or someone explain?
Old Nov 20, 2007 | 09:16 PM
  #280
EdKatt's Avatar
What I do, and I learned from tuning my chopper, is to raise the idle up about two turns in, it should have a steady rpm and "sound". Then you adjust the air/fuel mixture in or out to maximize your rpm. You will hear the rpm go up or down as you adjust it. Once you have achieved the max rpm, adjust your idle back down to where it was or where it seems good. Then you are as good as it gets without changing jets.
That screw on the right is the one you want.
Let me know if you need more!
Ed Katt
