ltz50 quad no power
Old Apr 14, 2008 | 06:21 PM
  #771
EdKatt's Avatar
Default ltz50 quad no power
You can change that sprocket but you still wont notice a big difference until you replace that cdi.
Old Apr 14, 2008 | 06:34 PM
  #772
EagerJeeper's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: EdKatt
You can change that sprocket but you still wont notice a big difference until you replace that cdi.</end quote></div>
I understand that. I am not trying to increase the top speed. I'm fine with the rev limiter. I want the thing to crawl well.
Old Apr 14, 2008 | 06:37 PM
  #773
EdKatt's Avatar
It does more than just increase the top speed. When its crawling through some thick mud or sand or at a good incline, you will benefit from more than 5000 rpm's.
Old Apr 14, 2008 | 06:57 PM
  #774
It does more than just increase the top speed. When its crawling through some thick mud or sand or at a good incline, you will benefit from more than 5000 rpm's.</end quote></div>
I have a three year old daughter who'll be learning on it soon. My two older kids will get an 80cc machine to blast around on. This one needs to be able to go slow and steady. When she gets a little more capable I might consider the ignition upgrade. Until then I'm not going to do it.
We have terraced pastures, and the kids like to stop halfway or two thirds up the terraces and then start again. I don't know why but they do. Traction isn't an issue. They just need more low end power.
Old Apr 14, 2008 | 07:00 PM
  #775
jeffnrivercity's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: EagerJeeper
We have terraced pastures, and the kids like to stop halfway or two thirds up the terraces and then start again. I don't know why but they do. Traction isn't an issue. They just need more low end power.</end quote></div>
The new CDI from CT has multiple settings so you can limit the rpms..or return it to stock with a flip of a switch under the seat...a nice feature if you putting a newbie on it
  #776
EdKatt's Avatar
Well definitely take the 3 rollers out, it gives it a little more bottom end and will slow it down a little. We dont mind the loss of top end because the cdi makes up for it. Good luck.
Old Apr 14, 2008 | 09:18 PM
  #777
greasemonkey2660's Avatar
Thanx for the link EagerJeeper now is decision time 43 or 48
Old Apr 14, 2008 | 09:35 PM
  #778
I have the 43 tooth and I wish it were the 48.
Old Apr 14, 2008 | 09:47 PM
  #779
have not steered me wrong yet 48 it is
Old Apr 14, 2008 | 09:56 PM
  #780
KINGQUAD450's Avatar
EagerJeeper
When we was running with the stock cdi it worked just as well as the 90 box as far as power, however it was on the rev limiter as so as he was on the throttle.(drove me nuts hearing that think sputter) It took him all of 5 minutes and he was begging to make it go faster again. But it climbed the hills just fine, in fact the one hill he even pulled the front off the ground.
But as far as speed for the nebies you can always set it down withthe throttle screw. Never ran it withthe 43 tooth so I can't give you a comparison between the two,sorry
