ltz50 quad no power
Old May 5, 2008 | 08:39 AM
  #931
yammadogg's Avatar
Default ltz50 quad no power
we want more out of the whole and climbing power already did the free mods would you suggest the cdi or shaving first ? nice to join been reading this for a while
Old May 5, 2008 | 02:01 PM
  #932
EdKatt's Avatar
CDI is easier, just plug it in. Milling the head is less expensive but more time consuming. I would start with the cdi.
Old May 5, 2008 | 05:39 PM
  #933
EagerJeeper's Avatar
If top end is not important I would mill the head and change the sprocket.
Old May 6, 2008 | 02:55 AM
  #934
edc7002's Avatar
It was hard as hell to find a spot that will mill that little head down out here in the Bronx... I found a place though; I'll put the bike back together Friday night after work.
I hope what ever top end I lost with the sprocket, I'll get it back once I install the milled head...
After this I'm done with moding this bike, it's gutless even with all these mods... It took my daughter 5 1/2 lap to run down a DRR and the kid was letting off the throttle on some spots of the track where my daughter was wide open the whole time... this bike just has no *****... I'm done with putting money in this thing
Old May 6, 2008 | 07:50 AM
  #935
KINGQUAD450's Avatar
Ok call me stupid but how are you planning on gaining top end speed by milling the head?Milling the head will not give you more rpms, so there for you will not gain any of your speed back.
Old May 6, 2008 | 08:12 AM
  #936
<div class="FTQUOTE"><begin quote>Originally posted by: KINGQUAD450
Ok call me stupid but how are you planning on gaining top end speed by milling the head?Milling the head will not give you more rpms, so there for you will not gain any of your speed back.</end quote></div>
If the motor has more horsepower it can maintain more rpm's through the rough stuff or over hills. In an unloaded situation with the machine on jack stands a modded motor might not produce more rpm's, but it will have the ability to better maintain high rpm.
In the case of our "little slugs" they need all the help they can get. More compression should certainly produce more power across the entire throttle range.
My 48 tooth sprocket should be here today. In a couple of weeks I'll probably pull the head on ours.
Old May 6, 2008 | 08:28 AM
  #937
yammadogg's Avatar
I think its running rich did you guys change the pilots and if so what sizes have been best i have stock air box extra piece off box and little wholes were the three rivets held it on spark arrester pulled with 1/2'' drilled through last baffle
Old May 6, 2008 | 12:50 PM
  #938
DSengineer's Avatar
Has been here a long time!
<div class="FTQUOTE"><begin quote>Originally posted by: yammadogg
we want more out of the whole and climbing power already did the free mods would you suggest the cdi or shaving first ? nice to join been reading this for a while</end quote></div>
THe CDI is a must if you ever plan on getting anything out of this little quad. Changing the CDI and removing 3 of the rollers made the biggest improvement of any of the mods I have done so far.
Old May 6, 2008 | 12:54 PM
  #939
DSengineer's Avatar
I think its running rich did you guys change the pilots and if so what sizes have been best i have stock air box extra piece off box and little wholes were the three rivets held it on spark arrester pulled with 1/2'' drilled through last baffle</end quote></div>
WHy do you belive it is running rich after having made modifications to allow more air into the motor??? If anything you are probably running lean. What is your elevation? Have you pulled the spark plug to read the color?
Old May 6, 2008 | 12:55 PM
  #940
jeffnrivercity's Avatar
I took the 48 tooth off my sons quad and my son is much happier...i will put it back on when we hit the sand again...we went to Prairie city OHV park last sunday,with out the LTZ50 becase it is a red sticker, so he rode his crf50 instead..try explaining to a 6 year old why he cant ride his quad..because of the red sticker restriction[img]i/expressions/face-icon-small-disgusted.gif[/img]
