BIG PROBLEM!
Old Jul 30, 2007 | 03:49 PM
hammertyme's Avatar
Default BIG PROBLEM!
my z250 does not start or run and its not even a week old.there is a full gas tank oil is fine dont know whats wrong.help me please.....
Old Jul 30, 2007 | 03:54 PM
Honeyduck96's Avatar
Check that kill switch is in the run position, then describe better what it does do when you hit the starter.
Old Jul 30, 2007 | 05:46 PM
hammertyme's Avatar
it sounds like it will start and then it dosent.i think it might be old gas because it was sittin in the dealer for a few years.
Old Jul 30, 2007 | 07:18 PM
Just gotta go through it step by step. If you're getting spark and you think it's the gas, clean your carb and try new gas.
Old Jul 31, 2007 | 08:23 PM
crazy1291's Avatar
procedure:
1) Try to start it. Will probably fail.
2) Remove spark plug and check for moisture/gas.
3) If the plug is wet, check if there is a spark when you hit the starter button. (hold the plug near, almost touching the engine. near, but not too near the hole as a flame COULD come out, maybe)
4) If there is a spark, and the plug is wet, check valve clearance.
5) Adjust valve clearance if needed. If it is not needed, check compression.
6) If all seems fine to you, go to dealer, let them sort it out.
Dont spend 3 months trying to figure something out if the dealer can do it in 3 days, with only 3 hours labor.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
