lt80 bogging puzzled & tried everything??
problem: idles but wont rev up unless I choke it manually with fingers over air intake
work done: clean all jets, complete carb overhaul twice, new plugs, adjusted richness etc...cleaned feul tank, filter petcock, all vacum lines , air filter, float seems to be working..
My thoughts -might have vacum leak, or crank case seal leak, did have some oil dripping a few weeks ago, also thought stator?
I have read many of LT80's postings and treads on this site and others...
Any ideas?
Thx
Any ideas?
Thx
You need to check your compression and your reeds. I had same problem. My reeds where cracked and had low compression. Put new reeds in and honed out cylinder with new piston and rings. works great.
