Eiger Idles Rough
Old Sep 4, 2007 | 09:52 PM
Scott267839's Avatar
Default Eiger Idles Rough
I have not changed anything and ran mime all day Sat. and Sun. It ran fine IF I LET IT WARM UP FOR 5-10 MINUTES. I plan to turn the pilot screw out another 1/2 turn and see if it helps. I forgot to check if it surges like you stated yours does.
swilliamfred, have you tried to turn your pilot screw out more yet? or took to a dealer? If so what did they find.
Old Sep 6, 2007 | 10:34 PM
swilliamfred's Avatar
Sorry I could not reply earlier, net has been down in the area.
I took a long shot and started looking at the fuel valve. Darn if you can not buy a new diaphragm for the thing. They make you buy the whole valve. I took it apart and saw that the diaphragm has a flap like a little briggs has. It was not in very good shape. The new valve arrived and I installed it and it will run at the lowest rpm and not skip a beat. I let it run for half an hour. Could not believe it.
Might be your trouble. Mine has over 4000 miles in the 5 years I have had it. I bet I am not the only one who has found this problem.
Good luck
Scott
Old Sep 12, 2007 | 01:58 AM
Scott, did you run it this past weekend? Still going strong? Did you try to run it with the fuel valve in the PRI position?
Ok to mine. I took fuel valve apart and it everything looked good including the diaphragm. Check reading on vacuum to fuel valve, good, comparied both Eiger's. I took carb out again and cleaned again and set pilot screw out at 5 turns. It ran rough like it was rich. I turned it down to 2 out. It ran good and then I went down to 1 1/2 out. Today I let it warm up for more then 10 minutes with choke on before turning it off. It ran fine after that but did die once. I want to try to warm it up just a couple of minutes and take choke off and see what happens. I might need to move the screw back out to 2 turns. I think there was somthing in the carb and it finally came out (although it looked very clean to me).
Old Sep 12, 2007 | 10:37 PM
I have put on a couple hundred miles in the last week. Runs like a new one. I have never tried running it in the PRI position.
Nosniborpapa
Sep 12, 2015 05:54 PM
Jaymc
Sep 11, 2015 07:45 AM
Minimod
Sep 10, 2015 09:20 PM
Hw00d
Sep 10, 2015 08:53 AM
Minimod
Sep 10, 2015 08:03 AM
