LTZ50 problems HELP
Old Nov 15, 2007 | 03:54 AM
tlronny's Avatar
Default LTZ50 problems HELP
<div class="FTQUOTE"><begin quote>Originally posted by: Quad Challenge
Hi, its the switch on the brake lever. It stops the bike over revving and damaging the clutch / belt if you have forgotten to release it after starting.
Either you have disconnected it to aid starting or it is stuck / broken.
Good luck !</end quote></div>
I'm sorta thinking this too !
We tried to disconnect it on our bike but discovered that it is connected into the stock CDI and therefore cannot be simply bypassed.
If it is not releasing after starting then it will make the bike rev limit very early
Old Nov 15, 2007 | 09:43 PM
moparman7's Avatar
now the more mess with it the spark is weaker and vary unconsistant now it wont even start anymore .
Old Nov 16, 2007 | 08:24 PM
DSengineer's Avatar
Has been here a long time!
<div class="FTQUOTE"><begin quote>Originally posted by: tlronny
If it is not releasing after starting then it will make the bike rev limit very early</end quote></div>
Me three... If its disconnected the CDI kicks in a really low rev limit
Old Nov 19, 2007 | 03:24 PM
mjlar94's Avatar
My DT used to do that when my main jets were too big. Maybe your float level got bumped up a little?
Old Nov 21, 2007 | 01:14 AM
  #15
joshua4898's Avatar
My son has a 2006 LTZ 50. I had major problems with the cdi. It wouldn't let it even crank. I replaced it and everything is good. From everyone that I have talked too they aren't that great. I just replaced it with a stock one for a 50 but from what I can read the way to go would be the one for the 90 I just don't know how reliable it is. Good luck.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
