oil in air box ltr450
If you have oil in the airbox and the quad isn't making strange noises...It could be you have too much oil (this happened to me). When doing oil changes, make SURE you undo the two 5mm crankcase bolts AND the engine oil resivoir bold. Also open the caps where you are going to replace the oil. This will make sure all the oil gets drained. Then add the correct amount of oil (400 ml or cc on right side (no dipstick) and 1200 ml or cc on the left side with the dipstick).
