running lean
Old Jan 3, 2008 | 04:13 PM
zz8t's Avatar
Default running lean
i recelently bought a suzuki lt230s when i rode it when i first got it i noticed a slight backfiring the next day i went out for a ride and thier were holes in the pipe
the back firing stoped but on the last ride the pipe fell compleatley off and it has started backfiring agin
i was just wondering if that was because of the lack of pipe or was it caused by running lean
thanks,zz8t
Old Jan 3, 2008 | 06:53 PM
LT80's Avatar
LT80 Expert
No pipe, no backpressure pulse, no run good. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 3, 2008 | 08:25 PM
JustRandy's Avatar
Backfiring is usually lean pilot.
First ride: Too much backpressure = lean pilot = backfire when you let off the gas.
2nd ride: Drain bolts fell out the bottom of the muffler and backpressure went down = richen up some = no more backfire
3rd ride: pipe fell off completely = less backpressure, but less scavenge at low rpm which is about the same as too much backpressure = lean pilot = backfiring when you let off gas.
Put the pipe back on and remove the drain bolts and have fun!
Old Jan 6, 2008 | 05:32 PM
zz8t's Avatar
it did not fall of it rotted into pices so i need to buy a new one
Frisky2050
Apr 9, 2020 11:19 AM
marioi911
Sport Quads
Jun 30, 2015 12:00 PM
Mphillips
Jun 26, 2015 03:52 PM
hoopduerr
Jun 10, 2015 03:00 PM
dano00
8
Dec 27, 2000 10:10 PM
