please help lt80 starter replacement
Old Feb 7, 2008 | 09:15 PM
yzwilly's Avatar
Default please help lt80 starter replacement
I haev tried to replace the starter on my lt80 and I am stuck do I have to pull the whole engine. I can't figure out how to get it out. If you know please help as I have already taken off the left side cover adn the bolts for the starter it is loose, but I can't get it out. Thanks
Old Feb 8, 2008 | 08:55 AM
LT80's Avatar
LT80 Expert
Welcome to the forums. [img]i/expressions/face-icon-small-smile.gif[/img]
They are hard.
Try removing the main bolt that holds the motor in and moving the motor slightly to get it out.
Old Feb 9, 2008 | 12:15 PM
qsportgoat's Avatar
i replaced my sons twice. remove the battery lift the front end up 90 degrees remove the front motor bolt. this will allow enough clearance. its a pain but just becareful when you move the motor around its a little top heavy. good luck
Old Jun 15, 2008 | 04:36 PM
atvnmama's Avatar
Our 80 is at a small engine mechanic shop now. The mechanic is saing the starter can't be replaced without removing the engine. Is there any specific info you can give for replacing the starter?
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 19, 2015 10:13 AM
Desimation2k8
Jul 17, 2015 12:37 AM
ghost civic
Jul 15, 2015 10:48 PM
mudpig79
Jul 13, 2015 03:31 PM
