1986 lt230s backfire
Old Mar 19, 2008 | 12:16 PM
tomkat510's Avatar
Default 1986 lt230s backfire
i just bought a 86 230s, the guy bought it from someone who most have put a pipe on it, but he didnt know if the guy jetted it, if you start the quad and rev the gas it will back fire alittle bit, how can i tell if it was jetted or if i need to jet it, is it hard and how to jet the carb the right way????
Old Mar 19, 2008 | 01:40 PM
270quadsportguy's Avatar
take it out on a trail when its warm and run two or three gears at full throttle, pull clutch and hit kill switch and hold clutch till u stop. Then pull the plug and see what color it is. If white u need to go with a bigger main jet. on my 230 with stock bore stock cam and a pipe i was using a 125-130 main jet and a 25 piolet with the d.g pipe
Old Mar 19, 2008 | 05:12 PM
JustRandy's Avatar
Sounds like the pilot is lean. Revving and then letting off followed by a backfire means lean pilot. Revving out and having it break up or backfire without letting off the gas means lean main or needle.
Old Mar 19, 2008 | 05:14 PM
Scooter86's Avatar
Knows Old ATV Questions!
<div class="FTQUOTE"><begin quote>Originally posted by: JustRandy
Sounds like the pilot is lean. Revving and then letting off followed by a backfire means lean pilot. Revving out and having it break up or backfire without letting off the gas means lean main or needle.</end quote></div>
I was thinking the same thing. Try going a little bigger on the pilot and see if that solves the problem. Another quick and dirty test is to see if it runs/idles better once it is warmed up with the choke on. If yes then your pilot is to small.
Old Mar 20, 2008 | 02:04 AM
if its got a pipe and stock jets it will backfire and it will sputter anything above 3/4 throttle. valve adjustment will do similar symptoms
Old Mar 21, 2008 | 10:21 PM
PoolGod230's Avatar
welcome! 230s help here http://forums.atvconnection.co...7657/STARTPAGE/149.cfm
lonerider856
Oct 13, 2023 03:45 PM
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
