LT80 carb tuning help needed
Old Apr 28, 2008 | 09:52 PM
carnut68's Avatar
Default LT80 carb tuning help needed
My sons stock 2001 LT80K1 runs like a scalded dog but smokes quite a bit (esp on throttle) and smells of gas. Plugs generally seem wet/fouled too. Obviously, it seems to be running rich. What is the procedure for adjustment? There appears to be only one screw on the carb for idle speed. I have heard that could be a combination idle speed/mixture screw but the manual says nothing about that.
Thanks for the help!
Jay
Old Apr 29, 2008 | 09:58 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
Like you noticed, there is no fuel mix screw.
Smoking is normal. Some oils smoke more/less.
You can put a 90 main jet in (down from 92.5) to lean it out a lil.
They are jetted way fat from the factory. [img]i/expressions/face-icon-small-smile.gif[/img]
Old May 1, 2008 | 08:19 PM
carnut68's Avatar
Some smoking may be normal, but this seems like a bit too much. And like I said, it smells rich too. I will re-jet it as a last resort but how should the idle speed screw be set? Does that regulate fuel mixture at all? Thanks again for the help.
Old May 2, 2008 | 08:39 AM
LT80's Avatar
LT80 Expert
The idle screw is just that. It does not effect the air/fuel mix.
Set the idle screw where the machine idles correctly.
What oil are you using?
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
clsharky
Jun 8, 2015 11:38 AM
Dieseltrash
Jun 6, 2015 09:53 PM
