Fan Problems
Old Jul 9, 2008 | 01:33 AM
MuddinAK's Avatar
Default Fan Problems
I have a 05 Suzuki Twin Peaks 700. I am having a problem with overheating and my fan not coming on. I had problems one day, it was fine the next and then the next weekend the fan wouldn't come on again. Anyone know of a fix for this? I have checked the breaker and it seems to be fine. I also have made sure to keep the radiator and fan area clear of mud and gunk.
Thanks,
Dan
Old Jul 29, 2018 | 12:21 PM
mpolacza's Avatar
I have the same issue what did u do to fix????
Old Jul 30, 2018 | 03:29 AM
Suspect MuddinAK will be long gone, that is a ten year old post. Most Suzukis have separate temp warning light senders and temp senders for the fan so, most likely, one of them is on the blink, either the fan one isn't switching on when it gets hot, or the temp light one is switching too early, telling you it is overheating when it isn't. You can test the fan is OK by finding the sensor and jumping the wires together where it plugs into the loom (if it is a two wire sensor). With ignition on, the fan should run. If that is OK you need to judge which sensor is at fault, if it seems to be really hot when the warning light comes on, probably the fan sensor at fault.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
