Freaking brake wont stop squealing!!!!!!!!!
Old Oct 8, 2008 | 09:05 PM
EdKatt's Avatar
Default Freaking brake wont stop squealing!!!!!!!!!
My wifes Z400 back brake will not stop squealing! I have taken it totally apart and cleaned everything! Should I change the pads or is it the rotor? Any one else with this problem?
Old Oct 8, 2008 | 09:19 PM
eggenz7's Avatar
might try taking a scratch pad and roughing up the rotor a little bit. maybe she rode the brake for a while and put a glaze on it. using the scratch pad will remove the glazing. just a thought
Old Oct 8, 2008 | 09:35 PM
mucky's Avatar
if the 07 rear brake is anything like the 03 it never went away. I changed the rotor to a vented one and its been quiet since
Old Oct 8, 2008 | 10:36 PM
EdKatt's Avatar
Thanks guys, yeah I took a pad and roughed up the rotor and pads to make sure they were clean and had no glaze. Put it back together and still there! I bet its the stupid rotor. My luck wont let it just be the pads!
Old Oct 9, 2008 | 09:39 AM
ss97's Avatar
Lets Ride!
Try some automotive "disc brake quiet" stuff...... it works with cars so I don't see why it won't work with ATVs also....
Old Oct 9, 2008 | 03:11 PM
atrodeoch's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: ss97
Try some automotive "disc brake quiet" stuff...... it works with cars so I don't see why it won't work with ATVs also....</end quote></div>
I second that. We had the same problem with our 400 LTZ. Worked wonders.
Old Oct 9, 2008 | 05:35 PM
EdKatt's Avatar
You guys mean that spray on grey stuff with the flakes in it? I have some of that stuff in the garage. Are you guys putting the gel stuff on the back of the pads also?
greg74
Sep 10, 2019 03:03 PM
Shainasmash
May 8, 2017 06:38 PM
Stirling
Aug 9, 2015 01:49 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
