LT80 Problem
Old Feb 3, 2009 | 03:54 PM
labguy's Avatar
Default LT80 Problem
Hey guys,
My daughter has an 05 LT80. I started it up a minute ago and rode it from the garage to the backyard to wash it. Ran fine. I pressure washed all the mud off and when I started it back up, it wouldnt go anywhere. It started fine, revved fine, but would barely move when I hit the throttle. Any ideas???? I use a 2000 psi power washer everytime we ride to clean them and never ran into this. Could I have damaged something washing it? Thanks in advance....Don
Old Feb 3, 2009 | 03:59 PM
atvman29's Avatar
Does it feel like something is slipping or dragging?
Old Feb 3, 2009 | 04:03 PM
labguy's Avatar
I guess....something has to be slipping. Before now, when I hit the throttle, it would jump forward. Now it just barely moves forward.
Old Feb 4, 2009 | 10:42 AM
labguy's Avatar
Anyone have any ideas??????
Old Feb 4, 2009 | 12:17 PM
95wolv's Avatar
Sounds like a wet belt, there should be a drain bolt on the bottom to let out water, even a little on the belt lets it slide on the pulleys, my kids LT80 would sometimes do that after a run through a big puddle, rev it up with the back wheels off the ground and it will blow out and evaporate the water, then the belt will hook up. you should have a little chrome inspection cover that comes off with three bolts, look inside, I bet you see water.
Old Feb 4, 2009 | 02:44 PM
labguy's Avatar
Thank you, you were evidently correct. Went downstairs and started it up, and it ran fine-no more "slipping". I removed that cover and i didnt see water but I did see what looked like to be oil. Is that normal? Thanks for your help.
Old Feb 4, 2009 | 05:39 PM
95wolv's Avatar
you were probably seeing moisture and belt dust mixed together, but the oil pump for the injector is run off the primary clutch drive,maybe a little leak there?
Old Feb 5, 2009 | 09:45 AM
LT80's Avatar
LT80 Expert
I never seen that leak.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Wnthunting
Jul 9, 2015 03:02 PM
