LTZ400 Oil Problem
Old Feb 8, 2009 | 05:22 PM
ronco1052's Avatar
Default LTZ400 Oil Problem
I have 04 LTZ400 the oil is backing up into the oil tank, the hose is clear between the oil tank and the motor, when I removed the motor drain plug very little oil came out I had to remove the lower oil hose to drain the oil from the oil tank.
Does anyone have any ideas or seen this problem before?
Old Feb 8, 2009 | 08:33 PM
mucky's Avatar
when you drain the motor very little will come out. you also have to drain the oil tank, there is a drain plug in it and you shouldnt have to remove the hose. the motor is a dry sump and doesnt hold much oil in it and pumps the oil from the tank through the motor and back to the tank. the tank holds about 2 1/2 qts
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
