LT230 Extended A-Arm Project
Old Mar 5, 2009 | 06:35 PM
  #21
atvman29's Avatar
Default LT230 Extended A-Arm Project
Here's mine, almost completed:
Old Mar 5, 2009 | 06:57 PM
  #22
lt230sman's Avatar
oh wow man, lookin good!
and everything looks so oem and clean!
good work man!
oh, and wat kinda shocks are those?
Old Mar 5, 2009 | 07:13 PM
  #23
lt230sman's Avatar
oh and just another quick thought, i'm thinking that those heims i found earlier (8mm to match the piviot/mounting bolt) are wayyyy too small. i really would like the inside diameter to match the oem bolt and be all fancy and what not, but unfortunatley, on all the heims that ive found the ID matches the shank, and 8mm is just too small. so i guess im going to look at 10 and 12mm ones, but not i'm not sure if they will clear the little webbings in between the frame tabs.
any thoughts?
Old Mar 5, 2009 | 07:40 PM
  #24
atvman29's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: lt230sman
good work man!
oh, and wat kinda shocks are those?</end quote></div>
They are the LT250S shocks and they are plush feeling! I haven't ridden with them yet though.
Old Mar 5, 2009 | 09:32 PM
  #25
JustRandy's Avatar
Yup, looks like 250R shocks ARE pretty close to 250S shocks: http://www.worksperformance.com/pdf/app_guide/atv.pdf Half inch difference... Not sure works measured them the right or if the S shocks are really longer than the R.
Thanks for the pic. Much easier to find 250R shocks than 250S shocks.
Old Mar 5, 2009 | 09:34 PM
  #26
lt230sman's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: JustRandy
Much easier to find 250R shocks than 250S shocks.</end quote></div>
exactly what i was thinking!
Old Mar 5, 2009 | 09:41 PM
  #27
JustRandy's Avatar
I'm not sure what to think about those little squares. Never saw an idea like that before.
Atvman, those red springs turned out nice! Sure brings out the red accent you have on the side. And I like the red n blue combo. Good Job! [img]i/expressions/beer.gif[/img]
Old Mar 5, 2009 | 09:45 PM
  #28
JustRandy's Avatar
any thoughts?</end quote></div>
Can you post some links to the hiem joints you're considering? I'm confused by what you're saying. Shank? Inside Diameter? What is 8mm? The size of the hole in the heim or the threaded rod of the heim?
And this i before e crap isn't helping, lol. [img]i/expressions/face-icon-small-tongue.gif[/img]
Old Mar 5, 2009 | 09:48 PM
  #29
JustRandy's Avatar
Atvman has 250S shocks, btw, just like the a-arms.
Old Mar 5, 2009 | 10:27 PM
  #30
lt230sman's Avatar
And this i before e crap isn't helping, lol. [img][/img]</end quote></div>
well, the bolts that go thru the frame tabs and actually hold on the arms by the bearings are 8mm, if i remember correctly. at first, i wanted to go with heims that had an 8mm ID (size of hole in ball) for a nice fit, but then i realized that the shank (threaded portion coming off of heim) would also be 8mm, which is WAY too small. so basically, now im looking into 10mm or maybe even 12mm heims. i guess ill have to use a bushing of some sort for a proper fit on the frame. the p/n that you can punch in on www.mcmaster.com for a cad drawing and specs is: 59935K85
