suzuki ltf500f problems
Old Feb 11, 2001 | 10:31 AM
coyote2's Avatar
This thing is bugging the heck out of me.I can get it to start but dies out after a few seconds.It backfires when trying to start.It even backfires after trying to start it,if it don,t start.Is it out of time,or what?
Thanxs Joe Wiley
1998 suzuki ltf500f (stock)
Old Feb 12, 2001 | 07:42 PM
BIG500ZUKI's Avatar
It sounds a lot like it has got a bit of water in it. One of our "crew" has a 99 and after too many water crossings it backfired constantly when starting, running, or idling. couldn't give it any fuel or anything. We took it to Suzuki and they ended up rebuilding the carb on it. Of course he swore it had never seen water or even driven past a water hole!! But, what happens is when you get into a bit of water, there are a couple little vent lines on top of the carb and they take on water very easily. I remedied this problem early on by adding some automotive vacuum lines and running them way up through the frame to the handlebars up by the brake cables. You can then cap them off with some GM type axle vent caps by adapting some larger fuel line or hose. It really is very easy and will save you a very long walk home. This works even if the air intake on your machine isn't "snorkeled", because sometimes in a crossing situation your airbox can take on a bit of water without drowning out the machine. Then the airbox drain tubes do their job and you keep on running.
Old Feb 14, 2001 | 08:58 PM
coyote2's Avatar
I would like to thank big 500 zuki for the info.It was greatly appreciated.
jaime511
Jul 19, 2015 01:58 PM
Jul 15, 2015 02:07 AM
clsharky
Jul 13, 2015 02:07 PM
sara durrant
Jul 6, 2015 05:32 PM
bikedad3
Jul 2, 2015 02:15 AM
