LT230S Rear Shock
Old Apr 12, 2009 | 01:14 AM
JustRandy's Avatar
This is the best pic I have of the mounts:
Old Apr 12, 2009 | 01:16 AM
JustRandy's Avatar
I basically mounted the 250S shock on the +4 swingarm and set the top mount so the seat height is 29-30 inches.
Old Apr 12, 2009 | 10:03 PM
lt230sman's Avatar
did you weld that mount on, or did you just drill more holes for different positions?
Old Apr 12, 2009 | 10:39 PM
lt230sman's Avatar
Originally Posted by atvman29
I'm not sure on the length of the 250S rear shock but I found this on eBay today:
Rear Shock
I don't remember seeing a 230S with an external reservoir so maybe that's a 250S shock? Then again, the 250S shocks should be white, but maybe its painted. Who knows. You could probably email the seller and ask him what the eye to eye is.
Hope this helps.
hey i finaly figured out what that was from, its an lt230e rear shock. and i think im gonna go for it. i just wish it had the threaded shock body like the s shock does, but hey its got a rezzie and should be the same length, so it should be nice!
Old Apr 12, 2009 | 11:51 PM
  #15
JustRandy's Avatar
I welded it on.
Old Apr 13, 2009 | 04:51 PM
  #16
lt230sman's Avatar
so then what about that mod you mentioned previously (probably in the mega thread) about cutting the stock upper mount, or something like that?
Old Apr 13, 2009 | 05:01 PM
  #17
JustRandy's Avatar
That was just to lower the back an inch or so with the stock stuff. With a new, longer shock, I didn't want the back higher than stock, so I had to make a whole new mount. I like the seat to be 29-30 inches unloaded.
With the stock stuff you can just cut some off the stock mount and then drill a new hole. Its simple and probably the best mod-per-effort you can do.
Old Apr 13, 2009 | 08:48 PM
  #18
lt230sman's Avatar
yeah, i think im gonna get a used 230E shock (rezzied' and same length as stock) and do the lowering mod.
do you have any expirience with the E shocks? are they the same spring rate as the S units?
Old Apr 13, 2009 | 08:56 PM
  #19
JustRandy's Avatar
I don't know. Never saw one.
Old Apr 13, 2009 | 09:54 PM
  #20
atvman29's Avatar
The 230E's had rezzies?
