lt230s unique problem lighting coil or regulator?
Old May 8, 2009 | 04:37 AM
bmk8's Avatar
Question lt230s unique problem lighting coil or regulator?
i have a 1985 lt230s quadsport. runs great. had no lights for years. popped in a new bulb in the taillight and it was bright. revved it up and blew the light. I replaced the regulator with one i had. it was a cheap one wire regulator i was going to use on a skidoo but didnt. now it is at a consant 14.5 volts. Now the problem. i hook up another light. weather it was 45 watt headlight or another 5 watt bulb for the tail light and both lights go way dimm. i have to rev it way high to get any decent light output. the lighting coil was new 2 years ago when i did the ingnition and pickup coils during a complete motor rebuild. So could it be the wrong regulator? i dont think the regulator limits the wattage. does it? or did my lighting coil take a dump? thanks for any help....mike
Old May 8, 2009 | 02:50 PM
NewportHillClimber's Avatar
there should be nothing wrong with your lighting coil. the tail light should only be a 5w and the headlight should only be a 45 watt. with the suzuki regulator it should be just barely above 12v. the regulator may limit wattage. you should only have to have it slightly above idle to get a good light burn
Old May 9, 2009 | 04:55 AM
bmk8's Avatar
Default new regulator
i will get anew regulator for it then. the one that is on it isnt a stock replacement. thanks mike
skittero
35
Mar 1, 2019 12:39 AM
WilliamBos
Sep 30, 2015 08:08 AM
scaldwellk
Jun 19, 2015 05:08 PM
Jbird4681
Jun 9, 2015 01:59 AM
gardner10
Feb 29, 2000 10:38 AM
