87 lt230e help
Old Jun 9, 2009 | 09:41 PM
74w100's Avatar
Default 87 lt230e help
Hi I'm new to the forums and to suzukis so I'm in need of help. When I got it, it was seized up and had no carb. I oiled it up and got it moving then put a 300 king quad carb on it. But it smoked so I re-ringed. It quit smoking for about a month and slowly started back, I rode it like that for a while about 2-3 months now and it has good compression. And its blowing oil out of the tail pipe so I just put new vavle seals in and it still smokes. So what do yall think should I ring it again?
Old Jun 10, 2009 | 06:10 AM
91Warrior357's Avatar
the valves them selves might be shot, you might have to reject that carb to work good for the 230 also since its a smaller cc bike, the bore on it could have pits and scores in it also that might be why its tearing your rings up.
Old Jun 10, 2009 | 11:16 PM
74w100's Avatar
I know the carb is to much but it's the smallest I had at the time. I'm not sure on the vavles one might be bent or something and as far as I can tell the bore is fine I honed it as best as I could. but I'm leaning towards the valves. It was smoking pretty bad and I still had good comp.
Old Jun 10, 2009 | 11:23 PM
yea maybe just get like 2 sizes down on the main on that carb and maybe change the needle if you have to and you might be fine, as for the valves i wouldnt be suprised if there worn since the motor was seized and all.
Old Jun 12, 2009 | 10:04 PM
74w100's Avatar
Well I re ringed it and cleaned all the oil out of the pipe and so far no smoke. But the old rings were messed up as far as I could tell. But hey it worked so I'm happy.
Proud Father
Aug 19, 2015 10:08 PM
azazel_18_2
Dec 24, 2012 11:10 AM
BIGBLUE6
Jan 4, 2011 07:49 PM
jacob_tamblin
Mar 17, 2010 09:56 AM
beechy
Mar 25, 2004 09:34 PM
