altitude adjustment
Old Sep 27, 2009 | 12:44 PM
dherold's Avatar
Default altitude adjustment
I have an 03 Vinson that I'm taking to 11,000 ft. elk hunting. What do I need to do to compensate for that altitude?
Old Sep 28, 2009 | 08:09 AM
Stoopidbot's Avatar
Adjust the main jet down 1 size for every 1000ft you are going up. I ride in Colorado, I have had my carbed quad up 13,800 ft above sea level.
Old Sep 28, 2009 | 08:24 AM
dherold's Avatar
Thanks. Colorado is where I'm heading. Is it as simple as pulling the jets out and replacing them?
Old Sep 28, 2009 | 09:57 AM
Stoopidbot's Avatar
On my quad, I take the drain bolt off the bottom of the carb's bowl. Then use a 6mm deep socket straight up through the bowl to grab the jet. As long as your carb is dialed in for what you got changing the main should be all you need to do. Be careful when putting the new jet in, I have turned it too hard and broke the jet. It was simple fix of replacing the needle jet holder. You may need to loosen the clamps on both sides of the carb so you can rotate it a little.
Old Sep 28, 2009 | 07:41 PM
dherold's Avatar
Thanks again! I ordered a new jet today from a local performance shop.
Dick.
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
wrencher82
Sep 30, 2015 04:27 AM
r1pilot83
Sep 27, 2015 07:38 PM
