87 and 88 lt230s shifters won't return
Old Oct 22, 2009 | 11:55 PM
j_daddy_o's Avatar
Default 87 and 88 lt230s shifters won't return
hey everybody! i'm new to the site and just looking for a helping hand, i have 2 lt 230s's and i recently got them back from a shop where i got the motors rebuilt, pistons, cranks, valves, the whole nine. So i get the bikes back and the shifters won't return, it's almost like the springs are missing from the shift forks? is there anything else that would cause them to do this, and also if the springs are missing or installed incorrectly will the cases have to be split again in order to correct this problem? any help will be appreciated! Thanks...........j_daddy_o
Old Oct 23, 2009 | 12:05 PM
bashr52's Avatar
I'd take it back to the shop and tell them to fix it. They were in there and obviously got something wrong on both of them, so let them fix it on their time and dollar. Does it shift at all, or just once and then stay stuck in gear?
Old Oct 24, 2009 | 01:44 AM
j_daddy_o's Avatar
Default shifter won't return
it shifts through all the gears, there is just no spring action, instead it is all free play so like when you kick it down into first, it stays down and when you try to grab second it is still way down and you have to hunt for it. I am going to take it back to the shop and make them fix it i was just curiuos if my hunch was right and they left out the shift fork spring???? or if anything else would cause that????
Old Oct 26, 2009 | 10:03 PM
NewportHillClimber's Avatar
there is a shifter return spring that is easy to put back on. but id make the shop fix it since they screwwed it up.
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Club News and Events
May 28, 2016 08:02 PM
Jeff Roper
Sep 21, 2015 02:11 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
