'05 Vinson Rear Brake Problem
Old Nov 27, 2009 | 02:46 PM
VaCity Madman's Avatar
Angry '05 Vinson Rear Brake Problem
I just replaced may rear caliper piston seals and brake pads on my '05 Suzuki Vinson. Now I barely have rear brakes. I have bled the brakes thoroughly and their is NO air in the lines. What could possibly be wrong?
Old Nov 28, 2009 | 11:27 AM
Hello? Anybody read this forum anymore?
Old Nov 28, 2009 | 02:00 PM
KQ400Pilot's Avatar
Check your fluid level again, then pump the foot pedal repeatedly--you need to push the piston out from the caliper until it makes contact with the brake pad.
Old Nov 28, 2009 | 11:14 PM
@KQ400Pilot - I have already done this when I bled the brakes. I took everything back apart today and cleaned everything and greased the pins. If I put ALL my weight on the foot pedal it will slow the ATV down. The last set of pads I had on it were the sintered kind and they wore down all the way to the metal within 125 - 150 miles. Could these pads glazed my rotor? Thanks for any info.
Old Dec 2, 2009 | 12:10 PM
lt230sman's Avatar
how does the pedal feel? firm like usual or squishy?
Old Dec 3, 2009 | 10:32 AM
@lt230sman - It feels somewhat squishy. The pads just will not grip the rotor.
Old Dec 4, 2009 | 02:38 PM
TexasRoadlawyer's Avatar
No Ruts, No Glory
Not knowing what condition your system is in, I'll hazard a few guesses here.
Do you get adequate pressure to stop when you apply the handbrake lever and not the footbrake lever?
Is there any damage to footbrake (bent lever/actuator, etc?)
If it's spongy, you may have a rubber hose line component expanding with the pressure instead of it pressurizing the caliper
You might also have a bad rear cylinder...as close as they are to the exhaust, heat does take it's toll on that component.
Do you have a Suzuki FACTORY service manual for your Vinny? They have a troubleshooting section that usually solves the problems (very few) I haven't been able to figure out myself
Old Dec 7, 2009 | 08:16 AM
@TexasRoadlawyer - The last set of rear pads I had on this ATV were the sintered kind and they wore down all the way to the metal within 125 - 150 miles. Could these pads, or I should say the metal behind the pads glazed my rotor? Everything else on the rear brake system works fine.
AK47KID
Jul 23, 2015 09:21 PM
rcappie4
Jun 21, 2015 07:40 PM
scaldwellk
Jun 19, 2015 05:08 PM
UPLou
Jun 7, 2015 09:42 AM
CountryMiles
Oct 25, 2000 01:03 AM
