Suzuki quadrunner 4x4 rear wheels inverted in?
Old Apr 20, 2010 | 10:59 PM
MN250R's Avatar
Default Suzuki quadrunner 4x4 rear wheels inverted in?
Im at a lost why the wheels sit like this in the rear.
i even had an extra right rear axle and it does the same thing. something bent on the frame? i got this quad for 300.00 bucks and it runs great, but it needed bearings and brakes so it didnt have the axles on it when i bought it so i was unable to see how the wheels sat. i believe i can fix it by adjusting the shock hole, that would straighten it up. but i thought i would check here first. thanks
Old Apr 21, 2010 | 07:44 PM
Sisco1957's Avatar
I think all with IRS does this. When you start riding the wheels will straighten out. there is nothing wrong with your machine.
Old Apr 21, 2010 | 08:00 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
It's normal - short travel IRS does that.
Old Apr 24, 2010 | 02:10 AM
Kenm's Avatar
The front suspension has dual a arms, and will keep the wheel perpendicular to the road as the suspension travels up and down. The rear suspension is a diagonal swing axle, as the suspension travels up and down the wheel will rotate about the swing axle pivot point, causing the effect you are seeing.
Kinda like the old V.W. bugs used to. In short, it's normal.
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
Bulgin88
Jul 30, 2015 05:20 PM
rcappie4
Jul 18, 2015 07:51 AM
bikedad3
Jul 2, 2015 02:15 AM
