05 eiger runs poorly and gets hot
Old May 18, 2010 | 10:31 PM
lemoncoke's Avatar
Default 05 eiger runs poorly and gets hot
05 eiger runs bad when you ride it for a little bit usually when it is hot. It shuts down but restarts when it cools down. Will run with choke on when its hot for little while, when you take choke off it dies. Thinking of wiring a toggle switch to it for a temp fix, because fan barely comes on. Problem started when it got water in the carb, cleaned the carb and still does it. Temp light doesnt come on when this happens. Any help would be great. Also how do you wire the toggle switch in. Thanks
Please help.
Old May 20, 2010 | 03:54 AM
beart0y's Avatar
Blockage in carb jets.
Old May 22, 2010 | 12:27 PM
Elk5012's Avatar
Exactly, something is blocking one or both of your jets (main and pilot) which is causing it to run lean.
Old May 22, 2010 | 04:00 PM
NewportHillClimber's Avatar
DEfinately runin lean. make sure your carb is clean and jetted to spec and ur air filter is clean and charged
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
Frisky2050
Apr 9, 2020 11:19 AM
neilbedwell
Nov 10, 2018 11:02 AM
Stillonit
Jun 18, 2015 11:23 AM
Steven Bandemer
Jun 14, 2015 10:47 AM
