LT230 Project
Old Jun 2, 2010 | 10:05 AM
  #21
PinkFloydEffect's Avatar
Originally Posted by Scooter86
Hard to tell on some of those parts. Do you have access to a parts cleaner?
If you aren't into re welding the side cover, I would try the JB or something along that line first. A lot of machines out there fixed that way and running fine. I just figured since it was apart it made sense to weld it for a stronger fix. Does the crack go through to the outside surface?
Well the hub looks clean I'm looking at it's thickness. Parts cleaner not really, I have lots of "GUNK" engine degrease I've been using (FADES PLASTICS!)
I don't believe the crack does, there is a bunch of gasket sealer on that area over the outside so MAYBE. I'll take a look and post a picture.
Old Jun 7, 2010 | 10:53 PM
  #22
Talking Update
So I decided to take the cheap-o way and use some Loctite quick set epoxy. I hope epoxy dose not decompose in engine oil once the pan is filled.
This is what the outside looks like, the previous jackhole did a nice and messy job with what appears to be some JBweld so I am not going to touch it but the inside is good so that's all that matters as long as it does not break down in oil.
Also I ordered some stuff online today, new spark plug, k&n oil filter, complete carb rebuild kit, 6 friction plates, and 5 new clutch disks.
Old Jun 10, 2010 | 08:44 PM
  #23
Talking I did it!
So I finally got around to doing it, there's no going back now but I'm happy with it, still needs some fine sanding and bondo, fresh coat of paint. But it looks much more mean for an lt230s grille.
Old Jun 11, 2010 | 02:55 PM
  #24
NewportHillClimber's Avatar
Thats a nice hood. check out my scoop i made for mine in my album
Old Jun 11, 2010 | 10:29 PM
  #25
That's a neat grille, you got a lt250 axle in yours??
All the parts came in today:
Decided to take a look into the air system and boy am I glad I did before I tried kicking it over!
Old Jun 13, 2010 | 04:18 PM
  #26
Scooter86's Avatar
Knows Old ATV Questions!
The airbox always makes a nice, comfy home for critters! You need to post some riding vids once she is all back together.
Old Jun 13, 2010 | 04:25 PM
  #27
Wink
No problem scooter, multiple cameras and angles all in HD! I do side time video editing as a hobby so you will be quite satisfied
Old Jun 13, 2010 | 10:11 PM
  #28
raiderfan2389's Avatar
nice pickup man for 60bucks lol.cant beat that im always picking up deals like that.i just picked up my 87lt230 for $450.my rear plastics are way worse lol.they make a plastic weld at autozone for about 5bucks that is really strong you could plastic weld those cracks n use a little more on the inside so its nice and strong.then sand down the outside and get it ready for paint should look cleaner than poprivets.and i like the cowl it look good ill have pics of mine on by tuesday.
Old Jun 13, 2010 | 10:32 PM
  #29
I'll have to take a look at autozone for that stuff. Anyone know where they sell (probably online) some of the same material they use on the seats so I can recover mine? After I'm done with this project I am going to try and trade it or sell it for a LT250r (most likely a somewhat project machine)
Old Jun 13, 2010 | 10:53 PM
  #30
just go to an upholestery shop they can recover it fairly cheap black would be nice.ill have pics tomorrow or tuesday of mines i got mine runnin just gota get it to idle.and yeah i hear you on the lt250r theyre nice quads i only picked up my lt230 cus it was cheap.might be picking up a blaster cus i like my yamahas.then eventually going to sell em both n move up to the banshee.
