carb problems
Old Jun 9, 2010 | 09:26 PM
Nickjones's Avatar
Default carb problems
We have a 05 vinson and we can not get it to run. i have taken the carb out and cleaned it and put it back in and still nothing. Even if i spray starting fluid in it. At first the gas would constantly run and would run back into the air box. Any ideas what it could be?
Old Jun 17, 2010 | 05:45 PM
Kerbbirds's Avatar
Bad needle and seat, float height, plugged jets?
Old Jun 21, 2010 | 10:23 AM
himsa169's Avatar
if your spraying starting fluidd in it and its not firing you have a spark issue not carb check spark
Old Jun 27, 2010 | 07:05 AM
papa hogg scoot's Avatar
Loved
Community Favorite
Also check compression, it cant combrust the fliud,,,also check spark like himsa advised..Good Luck.
Old Jun 27, 2010 | 07:54 AM
fallen angel's Avatar
If you have spark, if you have that much gas coming out of the carb you certainly have a bit of an issue with the shut off valve in the float bowl. You may get away with just cleaning this, may need to replace. Once you have that solved, you should likely change your oil as gas probably ended up mixed with it.
Old Jun 27, 2010 | 03:27 PM
2strokezilla's Avatar
is fuel spitting or spraying out back of carb? if so intake valve maybe out of adjustment
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
