Should i get it? - 86 LT230 for $900
Old Jun 14, 2010 | 08:31 PM
NewportHillClimber's Avatar
if you found a 230s for 500 that only smokes when its running, i would buy it. but i would check the swingarm bearings back axle bearings and front a arm ball joints as these are the most expensive to replace. but if you build the engine yourself you can do it and have 200 at the most in it. thats if it needs bored and a new piston bought. but as far as all the stuff to check it applies to all quads. hope this helps
Old Jun 14, 2010 | 08:43 PM
The Driving HotDog's Avatar
yeah that wouldn't really work lol. i guess i will keep looking for one, hopefully some more 230's will pop up.
NewportHillClimber: i guess you are right, i may go look at it sometime. what should i look for in the a arm ball joints? i have never seen good ones so i would not know if they are bad or not lol
Old Jun 15, 2010 | 04:07 PM
grab the front wheel and pull on them like checking the wheel bearings and if the ball joints move side to side they are no good. a little movement and they may last for a while still but you dont wanna ride too long with bad ones cuz they will release and your wheels will flop outwards. i had to learn it the hard way. mine flopped out when i jumped a jump and i landed right on the frame
lonerider856
Oct 13, 2023 03:45 PM
Shooterj2003
Jun 21, 2015 07:51 PM
scaldwellk
Jun 19, 2015 05:08 PM
230Srider
Jul 17, 2003 06:30 PM
QuadDude05
Jan 3, 2001 01:35 AM
