sunk my 4wheeler and now it wont start
Old Jun 29, 2010 | 07:54 AM
dixieboy1128's Avatar
Default sunk my 4wheeler and now it wont start
well sunday i went out ridin on my suzuki eiger 400 4x4 and i was goin across a pond when the snorkle pipe came outta the airbox an caused it to flood out. we pulled it out stood it up on the back rack to let the water drain out then pulled the drain plug on the air box. it still wouldnt start so i pulled it home. i have drained the oil, changed the plug and drained the bowl on the bottom of the carb an it still wont start. it has fire and ood compression.. what should i try
Old Jun 29, 2010 | 12:32 PM
anybody know of anything i can do to it
Old Jun 29, 2010 | 12:42 PM
Jaster94's Avatar
i'd flush the tank, i know methanol will leach on to the water, but unsure what it will do to the engine, i presume the motor would be robust enough like a car/pickup, make sure the carb is clean and getting fuel through the jets. pull the spark plug, crank it over a few times to make sure cylinder is clean, reinstall plug. i've read where people sank the quad, cleaned the carb, dropped all water, started it up, ran for ~1 minute, killed it, changed oil. 3X, and was fine after that. that's about all i know to do. but i'm just a shadetree guy. not a professional. the pros will weigh in on this one!
Old Jun 29, 2010 | 06:16 PM
i have tried that an still no luck
Old Jun 29, 2010 | 09:23 PM
NewportHillClimber's Avatar
check to make sure that none of the trash from in the pond clogged up your jets in carb
Old Jun 29, 2010 | 10:12 PM
Sisco1957's Avatar
I have an older Yamaha with the same problem. Cleaned carb,drained fuel & oil,checked valves and timing. Still won't start only backfire. The parts guy at the local Suzuki shop who is also a good mechanic told Me that The guys in the shop will rope start and electric start at the same time. He said the compression is low and it needs to spin faster to start and if you can get it started it will blow the trash from the rings and should be fine. He said to try pulling the atv behind a truck if it is manual shift. I haven't had time to try it yet.
Old Jun 30, 2010 | 03:24 PM
if it only backfires you may wanna check for an air leak on the intake.
Old Jun 30, 2010 | 07:00 PM
LT80's Avatar
LT80 Expert
"and drained the bowl on the bottom of the carb an it still wont start"
This is why we are recommending a good carb cleaning which includes removing both jets and cleaning all well, making double sure the jet holes are open.
You may indeed have done that, it just didn't say so.
I'd also be wiping out all the intake ducting. Could have dirt there now.
Old Jun 30, 2010 | 09:08 PM
hooked up a compression gauge an it was only 20psi.. so im think the rings sesed onto the pistion causing it to loose compression.. i guess its time for a big bore kit
Bigredjeep
Aug 24, 2015 12:27 PM
Bigredjeep
Jun 22, 2015 11:30 AM
BEEFKING69
Jun 17, 2015 12:38 AM
1000gade
May 27, 2015 12:37 PM
Mikes350X
Nov 20, 2000 04:04 PM
