King Quad Smokes when Started
Old Jul 29, 2010 | 07:08 PM
kawasakicowboy's Avatar
Default King Quad Smokes when Started
I have a 2005 700 King quad with 2,200 miles. I haven't started the machine in a month. when I started it for the first time the other day it blew a heavy smoke out of the exhaust which smelled like oil. Is it possible that the rings have turned?? or am i looking at bigger problems? The wheeler runs fine. It smokes for about 10 to 30 sec's and then goes away. after it's been running it doesn't seem to smoke unless it sits for a long period of time. Any suggestions would be appreciated.
Old Jul 30, 2010 | 09:48 AM
KQ400Pilot's Avatar
Check the valves for clearance and the stem guides for wear-oil could be oozing through. When the quad sits for a long time, the enough oil accumulates oil in the cylinder to cause the blue smoke at start-up.
Old Jul 30, 2010 | 08:36 PM
Default valves
i was told that you couldnt adjust the valves because there are no adjustment screws
Old Jul 30, 2010 | 08:38 PM
Default kq400pilot
is this going to be expensive?
Old Jul 31, 2010 | 04:19 AM
beart0y's Avatar
WHO TOLD YOU THAT??? 'Course they're adjustable. As far as oil down the stem- forget it. Won't do any harm unless you subscribe to this global warming crap.
Old Aug 1, 2010 | 10:56 PM
Talking valve adjustments
there are no set screws or nuts on the diagram he showed me.it has never had a valve adjustment.what all do i have to do to get to the valves,and how do i adjust them?
Old Aug 2, 2010 | 07:55 AM
KQ400Pilot's Avatar
Probably has "shim-under-bucket" valve train.
You measure the valve clearance, then swap the current shim with a shim that is thicker or thinner in order to obtain the correct clearance.
Old Aug 2, 2010 | 08:19 PM
Talking
thanx guys for all the info.
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
Scott-Leigh
Jun 6, 2015 09:10 AM
1000gade
May 27, 2015 12:37 PM
Wolverine16
May 18, 2000 09:18 AM
ferret3
Aug 4, 1999 08:23 PM
