LT80 Blues
Old Apr 3, 2011 | 08:53 AM
LT80's Avatar
LT80 Expert
Getting the clutch cover off is what takes the most time.
FYI's:::A impact wrench should be used to remove the clutch nuts.
To make it easy, I cut the footpegs in 1/2 and make a rod to reconnect. This allows the left footpeg to come off and out of the way.
The BIG nut on the rear clutch is left handed thread.
Get the head shaved .030 while it's apart.
105-115 inch pounds on the head nuts.
Arrow on the piston toward the exhaust.
The rings press against the cylinder walls, thus it wears out like you mention. Forget the oil and you'll see wear up and down LMAO.
Old Apr 4, 2011 | 08:40 AM
J-ROD's Avatar
Im having very similar problems with my LT80, but im not going to hijack this thread I'll start a new thread about my problems in just a little bit here, looking forward to some expert advice!
Old Apr 4, 2011 | 09:09 PM
Socrates Johnson's Avatar
Thanks again LT80, that's priceless information...I'll get to work.
QuadRiders
Oct 22, 2015 04:13 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
merryman
Sep 19, 2015 03:15 AM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
Jaymc
Sep 11, 2015 07:45 AM
